Hello Manfred,
Thank you for contacting us with your concerns. Could you let us know the exact issue you are experiencing when you try to launch AVG PC Tuneup? Do you receive any error message or error code? You could try to repair AVG PC Tuneup as described below.
Go to Start -> Control Panel.
Select AVG PC Tuneup in the list of programs.
Select Repair.
Restart your computer.
My TUNE UP has stopped working. I don't know why. Maybe it ist stopped by any virus-scanner. I have Avira and Spybot activated. A short time also advanced windws care.
I don't receive anny error message. It starts and end in one second.
I can see it in the task manager, but it is not working.
I cannot find the Control Panel, maybe becaus it is in German another name.
Hello Manfred,
Select Repair.
Manfred,
You can contact the German call support here +49 69 257 377 308 if you would like assistance in your German language.
