Two AVGs running
Hello Michael,
If you want to get rid of the older version of AVG, you can follow the steps in this article http://support.avg.com/SupportArticleView?urlname=How-to-uninstall-AVG to to run the remover tool to remove the old traces.
I have two Internet Security running.  The older showing underneath the newer one that I upgraded to a few months ago (Ultimate) in the bottom right hand status.  Windows 10 - 64 bit.  I get errors messages from the older versions saying it can not update definitions, but I open the control panel on the new one and is says everything is OK.  How do I get rid of the older one,  Likely conflicting with each other
Mike
Thanks, tyhe remover tool worked!!
Hello Michael,
