Recently I started getting an error message on start up for my laptop, which said:
The procedure entry point AvgLibCryptoInit could not be located in the dynamic library C:\Program Files (x86)\AVG\framework\Common\avguix.exe.
The other day, AVG could no longer update because, as it told me, there was an unfinished installation in-progress. I couldn't find any installation process that might be affecting it, so I tried to uninstall AVG and reinstall. It wouldn't let me uninstall because of the unfinished installation problem, and I could not run a replacement download of AVG for the same reason. HELP!
I apologize for the inconvenience caused to you.I kindly request you to run AVG remover tool : http://aa-download.avg.com/filedir/util/AVG_Remover.exe to completely uninstall your AVG program from your PC. Once uninstalled please try installing the AVG product on your computer.Please feel free to get back to us for any issues with AVG. Thank you.
