Uninstall AVG on Mac Problem
Hello M Gall,
We will help you to fix this issue.
In this regard, we'd suggest you to perform a clean installation by following the below steps & let us know if it helps :
Uninstall AVG from your MAC , if you've completed the installation process.
- Open Finder
- In menubar select Go > Go to Folder...
- Type /Library/Application Support/ and hit the enter key
- Locate and delete AVGAntivirus folder
- Reboot computer and AVG should be removed
- Download the setup file by visiting this link. Upon visiting the link, ensure that the locality isn't selected to any other region apart from worldwide or US. (You can check this with the flag icon displayed at top right corner in the above link - beside login to AVG account).
I'm getting this error even though I've already uninstalled the previous version: "AVG Antivirus is already installed, please uninstall the previous version first."
How do I fix this?
Thanks,
Hello M Gall,
- Open Finder
