Uninstall problems
AVG has ruined my laptop so that it takes ages to do pretty much anything now, I want to uninstall it but it says "another AVG installation or update is already in progress (error code 0xe001f921)"
i have 3 AVG items listed in programs :
AVG
AVG protection
and they won't uninstall so I need help and fast.
Sara, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hi Sara,
We understand your concern, not to worry we will definitely help you with that. We apologize for the inconvenience caused. Could you please attach us the screenshot http://avgclick.me/getscreenshot of the error message that you are getting?
Hi Sara,
