Hello Micahel,
We would request you to run AVG remover tool to completely remove AVG and then re install it.
I got a free webroot cd from Geeksquad recently when I had some work done on a different laptop. I don't want webroot and AVG to conflict. It just seems like overkill to have both. So, trying to uninstall AVG from add/remove apps in settings. Using windows 10. It won't let me uninstall. Says I have to uninstall AVG Protection first, but it won't let me do that either. Any ideas?
Oh, it was AVG Zen that I tried to uninstall first, when it told me I had to uninstall AVG Protection first. FTR.
Hello Micahel,
