Uninstallation/Repair problem
Hello Jasta.
May I know which AVG product are you using? I would request you to restart the PC once to close the setup that is already running in the background, and then try to uninstall.
When  I open AVG it says "Hmm… Let's try a restart instead. Sorry that refresh didn't work, but you're still protected. Try restarting your computer, or repair your installation" when i click "repair your installation" it says "Repair failed".
I tried restarting my computer and nothing changed. It's taking the most Disk and CPU in task manager and if I try to end task It just doesn't work.
I tried uninstalling It, but when I try it a window pops up and says "Setup is already running. Please try to start the setup later", but I have no setup window or anything like that, and there is a view log option, which shows a white box with nothing written in it.
Please help.
Hello Jasta.
