Update Ruined My Computer, no sound, won't uninstall - HELP
Hello,
I did the update on Friday and then once my computer turned on the sound on  my computer did not work. It says that Windows Audio is not enabled at the moment and I have tried everything to enable it but it will not work, gone into the sound, tried playing with the driver, nothing. I uninstalled AVG, restarted my computer and that did not help. I then did system restore to put it to before I did the update, did not help.
Now AVG is on my computer due to the restore and I have read that it may have quarantined the Windows Audio but now AVG will not open!!! I have tried to uninstall it using Control Panel but it will not work. I clicked "uinstall" and nothing popped up. I then did it again and I got an error saying for me "to wait until the current program is doing uninstalling/changing" but it is doing nothing.
Words cannot say how upset I am about this… I do not have cable and use my computer to watch things, listen to music, everything and AVG has completely ruined my weekend. Idk what to do and I'm very upset. I don't want to have completely wipe my computer… Someone please respond asap.
I was able to uninstall it but still no help… people are suggesting to check in the virus vault of AVG. If I reinstalll it will it still contain files that it had quarantined before I uninstalled it?
Hello L G, sorry to know this. I would request you to run AVG remover tool based on your OS (32-bit or 64-bit) to completely remove AVG. To determine whether your OS is a 32-bit or 64-bit, please click on this link. http://support.microsoft.com/en-us/kb/827218
For the audio issue, please try to re-install the audio drivers. Please revert us if the issue persists. Thank you.
Hello L G. I am sorry but the vault will be emptied once you uninstall AVG. I would request you to restore your PC to an earlier date where it is working fine. Please have a look at this article http://bit.ly/1ljkL5X . Thank you.
