Update speed very low
Hello Andreica,
We are sorry to know that. We suggest you to temporarily delete all the old updates of AVG and initiate a new one and see if that fix the issue.
Thank you
I downloaded and installed AVG and now it started doing an update but I noticed that it was going very slow, so I checked the download speed and it is 15.8 KB/sec then it goes to 0 then back to 15.8 and it keeps doing this non-stop. The update is downloading (currently downloaded 7.6 MB out of the 114 MB)  , even with this speed, but it will take a long time… my internet is working perfectly otherwise, so I need some help fixing this problem. Thank you in advance!
PS: I am using windows 7 64-bit, in case it helps.
This happens to me constantly.  At the same time, it will not allow me to get to some URLs.  It is extremely annoying.  The only option I've found that works, is to use the Remover tool, reboot, and reinstall AVG.  Then everything is fine for a while and it happens again.  I wasn't going to renew AVG, but I didn't realize I had it on auto-renew.  Now I'm stuck with it for another year.  UGH!
I am using a free version. But I saw the option of  "Update from directory" does that mean I can manually download the update and apply it? I think it would be faster.
Nope, it didn't work, speed is the same…
Hello Andreica,
We are sorry for the inconveience caused.
Are you using the free, trial or paid version?
