Hello Shh,
We are glad to help you.
Could you please specify your concern with AVG in order to understand better and provide quick solution?
From the description, we are unable to understand what your problem is.
Thank you for your reply.
1. We proceeded to install the avg program as a client pc from the window server to remote administration.
2. Remote administration has expired.
3. I purchased a business management console product.
4. The avg installed on the client.
Do I need to remove it and install it again?
(Through the business management console)
If you don't understand the question, please contact me again.
Hi, we was use this product remote administration.
We are Upgrade to business management console few day ago
The installation proceeded by spraying the product to the client through the existing remote administration.
Can the client pc use the product after the upgrade business management console?
If can't use remote administration for client version need a new installation, please give me a guide.
Thank you.Thank you.
Hi Shh,
Thank you for replying back to us.
From your description what we learned is that you want to install AVG Business product on your client PC.
We would request you to contact our AVG Business support team for this issue since you have reached AVG technical support for Home users.
You can contact them using this link: https://bit.ly/3hyL22D
