URGENT HELP pls
Hi Kristian,
I understand the situation. Don’t worry I'll help you with your issue.
Please follow all the steps provided in the following article to remove AVG completely from your computer and then continue with a fresh installation: How to troubleshoot issues after upgrade to the latest AVG antivirus product
Note: Please run the AVG Clear first and then the AVG Remover
Also, AVG Internet Security will not change your View in Program List. Please change your View to Details to see all the information.
Hi Kristian,
Please run the AVG Clear and then the AVG Remover again. If AVG Remover does not detect any version of the AVG product on your PC, click Run anyway to remove leftovers.
Hi Kristian,
