Utorrent not running on AVG VPN when it is ON
Hello Vernell,
We are here to help you. I’m sure we can figure this out, and we’ll work on finding a solution right away! Please check in the AVG Secure VPN to which server you have connected to because, in some locations, the use of utorrent is banned. If you have connected to that particular server then this website will be blocked. Please change it to a different server and check if that fix the issue (Open AVG Secure VPN > disconnect > change location > P2P > select a nearby location).
Regards,
I recently downloaded the free trial for AVG VPN, and now my utorrent won’t download anymore, tried to log out, change country (tried alot of it), logged back in and it did not work, now i followed a instruction to temporarily disable AVG proctection, bottom right (system tray), right click on AVG, turn off protection, AVG VPN is ON, then start downloading on utorrent, still not working, the only way it will work is when i turned off the VPN. Any advise or any help how to make this work?..
Hello Vernell,
Regards,
ive tried this and it hasnt worked
