Love to help but information you furnished is way too limited.
Expand on the problem and be more specific.
Good luck.
Ran scan and it came back clean.It is not and continues to be a problem.Ineed help
Hello Raymond,
Our technician "Viveksaravanan Neelagantan" had earlier tried to guide you to get connected to AVG Technical chat support team so that we will be able to assist you through chat and if possible we will also be able to escalate the issue. How long are you facing with this issue? Do you find any suspicious activities in your computer? Do you see the message 'You are protected' in your AVG main window? Please provide as much as information regarding the issue which will help us in assisting you better.
