Thank you for providing the AVG software version information.
Please open the AVG Internet Security dashboard and click on "Menu–>Settings–>Components"
To the right scroll down to Firewall and click on "Customize" option to the right.
Click on "Network Profiles" and to the right change the profile from "Public" to "Private"
Click on Ok and then check whether you able to access the vmware player.
Hello David,
I am sorry to hear this. Have you installed the latest 2017 version of AVG Internet Security?
I am using vmware player, and one of the vm is using bridged network connection. When AVG firewall is enabled, the vm loses network connection. I have fiddled with the firewall settings, but it didn't work. Currently, the only way to gain network access from the vm is to turn off the AVG firewall. Is there a solution to this other than turning off the firewall?
Hello David,
The software version is 17.4.3014, and I belive this is the latest.
