VPN and wireless printer
I have a wireless system that broadcast in 2.4 and 5ghz My computer connects at 5 but my printer connects at 2.4. Does the VPN work on the printer at the different frequency?
Hi David,
We're glad to help you with the info.
You may sometimes experience a slower internet connection when using Secure VPN. This is because VPN encrypts traffic and data before sending it to a server.
Depending on the distance and capacity of the server, this process may cause a slightly slower, but safer, internet connection.
However, you can try connecting to the optimal location (server) via VPN to check if it helps.
Usually, the frequency of the network devices will vary & the frequency drops. Thank you for your understanding in advance!
Hi David,
