Hello John, I would request you to follow the instructions mentioned in the following link http://www.avg.com/us-en/faq.num-4333 .
Please feel free to contact us should you need any further assistance.
Hi
Allow any traffic to virtual private networks (VPN) is ticked.
Firewall allows SSTP & PPTP, but not IKEv2
John
Hi
I’m using a VPN service with IKEv2 connection, but can’t connect past the firewall. If I disable the firewall it works.
I’m using AVG internet security 2015, are there any setting I need to change
John
Hi
John
Hi
Tried using AVG_sysinfo tool, but it ran for hours with no result.
Found runner_en.exe on forum with people who had the same problem.
Ran in last week, but got no reply from AVG
John
Hello John. Thank you for trying it. Kindly configure your AVG firewall as instructed in this article. http://www.avg.com/in-en/faq.num-5208 . Hope it helps. Please feel free to contact us back should you need any further assistance.
