VPN drops out ..now advised there is a technical problem and it will not connect
Hello Frank,
Let's work together to fix it.
Please follow the steps suggested here: https://support.avg.com/SupportArticleView?urlname=AVG-Secure-VPN-FAQ and check if that helps.
Let us know if you need further assistance.
Why does my VPN keep dropping ? Why doe sit not connect and advised there is a technical problem…happened a few times to date…have to reinstall ?
Hello Frank,
