Hello Daniel,
It is necessary to identify the root cause of the issue.
Hence, we sent an email instruction which will help you to get connected with our additional support.
If the email is not found in inbox, do check in spam and junk folders.
Hi, as soon as I enable the VPN, it disconnect the wifi internet connection. I have re-installed VPN and also AVG but same problem.
Hello Daniel,
