VPN ran into a technical problem
Hello Volkan,
We are sorry to know that. We'll check and help you out.
May I know whether you have installed any other Antivirus apart from AVG on your PC?
Awaiting your response.
I can not open secure vpn. it gives me
and below that ''Sorry, cannot connect to internet''
Thank you for writing us back, Volkan.
We are sorry to know that. In that case, please repair the program, reboot the device and check the issue.
I can't even see the location section on the app
The Link is not working
Thank you for the information, Volkan.
Please try changing the location of the VPN and check the issue.
If the issue persists then kindly repair AVG Secure VPN using the below article and check if it helps.
https://support.avg.com/SupportArticleView?urlname=repair-avg-antivirus
Thank you for writing us back Volkan.
Upon checking you have already connected with our technical team and they will help you with your concern.
Please feel free to reach us again if you need any other help with AVG.
Hello Volkan,
Thank you for replying.
I apologize for the trouble caused.
Please try in a different browser.
If issue perists, please feel free to contact us anytime.
We will certainly help you out.
