Hello William,
We regret to inform you that the AVG Secure VPN is no longer compatible with the Windows XP operating system.
In this case, we recommend that you upgrade the operating system of your computer & then install the AVG Secure VPN.
Thank you for understanding in advance!
I am running on a PC with Window XP. Until yesterday my AVP Secure VPN was working perfectly but now it won't establish a connection and I get a message "VPN ran into a technical problem". i have already removed it from the system and then reloaded it but this has not helped the problem. Can anyone help?
Hello William,
