Vpn ran into a technical problem
See users with the same problem… Uninstall and reinstall has not helped and my network and internet connection is not the problem
Hello I Barnard,
We will look into it. Please share the screenshot http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot of that error message you received.
Check the problem I have, the damage it can cause, how little avg can do to fix their software malfunctions and decide if you really want this software…
