VPN secure connection problem
Hello Nicholas,
Could you please restart your computer once and check whether the issue persists?
I have AVG Ultimate 2017. I downloaded the Secure VPN trial but it doesn't seem to work. I press the swich from off to on in the Secure VPN tab, a loading tab is opening but after a few seconds it closes and the VPN swich remains to off… any ideas?
We are happy to know that your issue is resolved. We appreciate your time and co-operation.
Thank you
Thank you
Hello Nicholas,
Yep that solved it! thanks a lot!
