Web Shield disables MS Edge Secure SNI (ECH)
When AVG Web Sheild is enabled, Secure SNI (Encryped Client Hello) gets disabled on Microsoft Edge, fails SNI (ECH) online tests, such as at Cloudflare Browser Check. When AVG Web Shield is disabled, Secure SNI passes on Edge.
HOWEVER, this does not happen with Google Chrome nor with Mozilla Firefox, just Edge for whatever reason. So for now I have to use Chrome for full security, but would prefer to use Edge. Please fix this bug.
Hi @Brian_Schiller , I’m sorry to hear about this experience. Could you please send us logs from your system? The steps are described here: Submitting a support file using AVG SysInfo | AVG
For ticket number, enter 333811 . Once the logs are uploaded, please reply here with the File ID.
Oops… UPDATE: Disabling QUIC (Experimental QUIC protocol) in browser Flags options made the SNI/ECH security check fail again. Odd. But disabling QUIC/HTTP3 scanning in AVG Web Shield does do the trick tho, security check passes.
I’ve resolved the issue. One of two options were available to get SNI/ECH security checks to pass, one was disabling Web Shield’s HTTPS Scanning, which seemed illogical, and the other was disabling QUIC/HTTP3 scanning. I’ve looked into this and seems others have complained about QUIC/HTTP3 scanning, including with Norton AV. I went ahead and disabled QUIC in both Edge and Chrome via Flags.
Nice detective work. The QUIC angle makes sense to me — when Web Shield intercepts QUIC/HTTP3 traffic it can trip up the ECH handshake, so the check fails even though TLS itself is fine. Disabling QUIC in the flags is a decent trade-off too, you keep Web Shield’s HTTPS scanning intact.
