Hello Arkan,
Please accept our apologies for the inconvenience caused.
In this case, we'd recommend that you reinstall your AVG Antivirus Free using our Clear tool & check if the issue persists.
Refer to the below articles to perform the clear reinstallation:
- Uninstalling AVG Antivirus Free using Clear
- Reinstalling AVG Antivirus Free
Let us know if the issue stil persists after the clear reinstallation.
Hello Arkan,
On AVG AntiVirus Free, if I disable the Web Shield then Remote viewer will work.
I'm trying to use SPICE to connect to my Proxmox console through Remote Viewer
I tried to add it into Exceptions but it did not work. I also tried to disable the options from Web Shield basic protection:
- Enable HTTPS scanning
- Enable QUIC/HTTP3 scanning
- Protect against botnets
- Enable Script scanning
All they did not work, except to disable the Web Shield
Any idea to solve this issue without disabling the Web Shield?
Thank you for sharing the screenshots, Arkan.
We have already sent you an email asking you to connect with our AVG free remote technician and please reply to that email for further assistance.
Thank you for replying back to us, Arkan.
We are sorry to know this.
May I know in which browser you are facing this issue?
Is it happening on all the browsers or in any particular browser?
Is there any other conflicting antivirus installed on your PC?
If yes, please uninstall it and check if it helps.
Thank you and keep us informed.
We have sent you an email asking you to connect with our AVG free remote technician and please reply to that email for further assistance.
Hi Midhun,
Thanks for your reply. I've done what you've suggested.
1- I've uninstalled AVG using AVG Clear
2- I've installed AVG
But the issue persisted, and as I mentioned in the previous post, it will work only if I disable Web Shield,
Best regards,
Arkan
