Hello Aaron,
We will work together to sort this issue.
Please share the screenshot https://support.avg.com/SupportArticleView?urlname=AVG-Create-screenshot of the web shield disabled screen. We will check the same and assist you further.
Okay! I will try to contact them again. Thank You😁
* my other apps keeps turning off too.
Hello Aaron,
Thank you for sharing the screenshots, Aaron.
For further assistance in this regard, we recommend that you contact our designated mobile team directly.
You can use this link to contact our mobile team via email.
Thanks in advance.
We understand your intent in posting your query in the Community Post, Aron
But I would recommend you to write back to them for further assistance.
Because they are the dedicated team for the Mobile Support.
Thanks in advance.
