Webtune up not downloading and unresponsive pop ups
I have gotten it from the antivirus free program regularly, it shows up under the name of avg Internet security.  I actualy was able to find where to make the pop up come on command which is when you click on the update feature under avg antivirus free, it has updated a couple times with the same exact same upgrades each time, when I click on "protection is up to date" the program crashes and restarts after showing the same pop up window I described going unresponsive.
Hello Evan. Yes, there is an issue with AVG Web tuneup installation freezing upon 85% and there will be a fix for this soon. Could you please let me know from which program do you receive the message saying to install the new features?
i have been having 2 diffrent issues. the first is that no matter who many times i try, avg webtune up will only install to 85% on my google chrome and no matter my efforts will not add to my extensions. i have uninstalled avg zem, google chrome and deleted all files of webtune up from my program files…no fix.
the second issue is regularly (at least 3-4 times a day) a pop up/notification will show up  asking if i want to add new features that i am entitled to with the avg package i am subscribed to, the problem is every time i go to press a button the window becomes unresponcive and only teminates when forced to do so by task manager.
i have had AVG for 3 and a half years now with no problem, the moment i get windows 8 and try to use the programs i have issues. i have talked to a tech support representative and they say the first is a common issue. is there any one out there who can confirm this and if so has anyone found some actual solutions to these problems? any advice would be vastly helpful, im begining to lose faith and wondering if its time to find another software to move to. i dont want to do this but if i cant get the full productivity out of a program im paying good money for, i will do what i need. thanks ahead of time!
Hello Evan. Please be informed that they are legitimate pop ups from AVG which our customers who are using AVG free version will be receiving to upgrade to 30 day trial version of AVG Internet security. I request you to ignore such pop ups. If you have already installed the trial version of AVG Internet Security please follow the instructions in this link: http://bit.ly/1073t3Z to downgrade to free version.
