Hello Victoria,
We understand that you are unable to login into a website as AVG says it is infected.
We are really sorry to know this. We'll certainly check and help you out.
Since you suspect that this is a false detection being made by AVG, please submit the detected website for false-positive analysis using this link: https://www.avg.com/en-gb/false-positive-file-form#pc
Once you've submitted the false-positive report, our concerned team will analyze the website and if found harmless, they'll whitelist it right away. Furthermore, they'll update the status via email.
Thank you for understanding in advance!
I am trying to log into "inboxdollars.com" and AVG is blocking my connection with the message "We've safely aborted connection on api.inboxdollars.com because it was infected with URL:Scam. How can I get into inboxdollars.com?
Hello Victoria,
