Why does AVG prevent me loading a legitimate national Sky help forum?
Hello Stephen,
We apologize for the inconvenience caused to you.
We certainly check and help you.
Upon checking the screenshot the issue seems not to be an AVG issue.
Let us disable AVG and check on it.
| AVG (https://support.avg.com/SupportArticleView?l=en&urlName=disable-avg-antivirus&q=Disable+AVG)
Please check if the website is loading without any issues after disabling AVG.
Thank you and keep us posted.
We're sorry to hear that the issue still persists, Stephen.
As we're unable to access the screenshot you've attached in your initial post, we've asked you to share it again.
In this case, we request you to reinstall your AVG Antivirus as mentioned in the below articles & check for the issue:
Also, please make sure that your Google Chrome browser has been updated to it's latest version.
Let us know if the issue still persists after a clean reinstallation.
Whenever I use Chrome as a browser, and I try to open a link from an email notification (or even just direct) on the Sky community help forum, AVG WebShield prevents it opening, and gives me a 'privacy error.It works perfectly well in FireFox. This is the message I get…Why does WebShield prevent me seeing a perfectly legitimate web site?
Hello Stephen,
Error still persists. Please see first post for the screen shot of the message I get. Definitely an AVG issue as when I disable WebShield, it works perfectly. It also works find in FireFox, it's 'Chrome' where the error meassage is generated.
chrome privacy error
Thank you for updating the status, Stephen.
If you think that the 'Sky Help Forum' website is safe to access, you can add the website to the AVG exceptions list, which will temporarily resolve the issue.
However, if you'd like to get this issue further investigated & resolved, please use the email we sent earlier to contact our additional support team.
They'll try their best to resolve the issue and if they can't, they'll collect the necessary AVG diagnostic logs & escalate your case to our higher level of support.
Chrome is tootally up to date. Version 107.0.5304.107 (Official Build) (64-bit)
I will once again attach a screenshot of the error message below…
chrome error
