Hello Ian,
I can understand your concern. However, this issue does not seems to be related with AVG. Please check if the airplane mode is enabled in your computer, if so, please disable the same, so your computer will get connected to the wireless connection and also make sure that wifi is switched on in your computer.
I have AVG on my PC and laptop. The wireless connection on the laptop has been working fine for sometime, until I disconnected it and took it with me over the weekend. While away and now, it will
not connect to the wireless. Is this an AVG settings issue ??
Hello Ian,
