Wireless Display Adapter AVG Blocks Connection
Hello David,
We are sorry for the inconvenience caused. We will check and help you to resolve it. Please provide the following information to help you better.
1. What are all the AVG programs installed in Windows 11 device?
2. Have you tried to disable each component in AVG Internet Security? If not, disable AVG component one by one and check it.
We look forward for your response.
I have a similar problem. The firewall is blocking my connection to TV's & Microsoft Display Adapters. Only solution I can find it to turn the firewall off
AVG Blocks my Microsoft Wireless Adapter and my Samsung TV when I try to connect my ASUS PC to watch films etc. Have to turn off protection to make it work, this is not ideal given the annual cost of AVG. Cannot find a way to tell AVG to allow it to work. Help! I am running windows 11.
Hello David,
Hello Darren,
We'd like to clarify this for you.Please write back to us in a separate private post so that we can check and assist you accordingly.
Thank you in advance!
