Wireless IP issue
Hello Dan,
I regret for the inconvenience caused. Please disable AVG Protection temporarily and right click on the wifi icon and select troubleshooting and try to fix the problem. This should add an valid IP address to your wifi connection and allow the internet connection. Once the connection is established, you can enable AVG Protection.
To disable AVG temporarily, please right click on the AVG icon present at the bottom right corner of your desktop(System Tray) and you can see a scroll bar to "Disable Protection". Please click on the same to disable AVG Protection and after which check if you are able to access Internet.
"Wireless does not have a valid IP Configuration" error occurred right after I renewed the AVG Ultimate subscription. I was unable to access the internet on my computer. Other computers not yet renewed did not have this issue. It was necessary to uninstall ALL AVG products to access the internet. Is this a known issue, because if it is I need to unsubscribe.I was without internet access for nearly 4 weeks on this computer.
Hello Dan,
