Hello Hope, could you please try to restart your modem?
No virus found. Regards, Hope
Hi AVG Community,
I did a full AVG scan yesterday and then today when I went to log on the Wireless Network Connection icon on the lower right hand side of my laptop showed the yellow sign that it was not connected. When I left clicked the icon the connection to my modem was showing limited access. I contacted my internet service provider who established that I do have connection and that it was only the driver to the laptop that had been corrupted. As the last think I did before logging off was to run the full AVG scan I checked on the web and someone else had mentioned the same thing although there was no solution that helped me.
I am wondering if you can help me to solve this issue as although I am able to use the internet it is daunting to see the yellow star covering the icon. I have tried to paste a screen dump but it did not take on this access.
regards,
Hope
Hi Avinash,
Thank you for getting back to me however as I mentioned above, the internet service provider spent about an hour with me and he took me through all the network adaptors ie the wifii and the backup that Microsoft software has and the ethernet adaptor. They are all the latest drivers and working fine that is why I still have connection to the internet. What changed after the AVG scan was the icon on the bottom right hand corner has a yellow sign over it and when I open it it says Limited Access to my wifii and no internet connection. So there has been a change made there during the scan.
Regards,
Hope
Hi Hope,
For help on this issue pelase try disable AVG Advisor nofifications.
Hope, does the scan found any infections and removed them?
