I just installed AVG VPN and my printer is no longer connected to my network?
Hi Glen,
This is an expected behavior.
Some websites and servers restrict VPN use. In these cases, you need to use your physical IP address. Rather than disabling your VPN every time you want to access these sites, you can set up a permanent VPN bypass so your physical IP address is used automatically.
Refer this article and setup the bypass for the wireless printer (3.Set up a VPN bypass route) https://support.avg.com/SupportArticleView?l=en&urlName=AVG-Secure-VPN-exclude-server&supportType=home
