Wireless Settings
Hello,
Can you please provide some information on how I should approach this ?
Thank you
Hello Scott,
I am sorry for the inconvenience caused.
It is not recommended to uninstall AVG program until we find what is causing the issue.
If AVG is causing the issue the program should be present especially the AVG PC TuneUp that changes settings on your PC.
Did you uninstall both Internet Security and PC TuneUp program from your PC completely?
Did you check whether the wireless connection is working on another device like mobile or tablet?
Hello,
I purchased AVG Ultimate to ensure that my virus software was up to date on all the PCs in the family. Since installing my wireless settings have stopped working and so unable to access wifi on all laptops. I have had to use an Ethernet cable and now spent an age trying to fix. I have updated drivers on Dell website, uninstalled AVG and also uninstalled wireless software completely to no avail. Can someone please help as I am desperately trying to find a solution that will work, thanks
Hello Scott,
Hello,
Thank you
Hello Scott,
I appreciate your patience in this matter.
It is necessary for us to analyze the AVG log files to identify the exact issue.
I have sent an email instruction to collect and send us the log files.
If the email is not found in inbox, do check in spam and junk folders once.
