Hello Gerard,
We will check with it. Are you able to access that website without any issue when AVG is disabled? Let us know the name of AVG program you have installed.
Right click on AVG icon under system tray next to clock, click on toggle bar to disable AVG protection temporarily.
Dear all,
is it correct dat all users from avg get problems
with the website grimas.nl. Webshop stops working white screen or ssl error. And with the productinformation part i get that pictures will not load. And when go further and back the pictures are loaded. When pictures are not shown it gives ssl errors. The same website grimas.com on a other server does not have this errors. Please help what could it be?
kind regards
Hello Gerard,
Thank you for the information Gerard,
I request you to change AVG Firewall network profile to private (open AVG Internet Security > menu > settings > components > firewall > customize > network profile > change all the network public to private), please go to Firewall customize settings again > scroll down > click on system rules > enable all the system rules if it's not configured, please click OK and check if you can access the websites with enabled AVG Internet Security.
If the issue still persists, then please disable AVG Internet Security components one by one and check which one is blocking the website.
Regards,
