Hello Celia. I truly appreciate you in finding out the resolution by yourself. Please feel free to contact us again if you are in need of any assistance. Thank you.
In Despair . . Link above doesn't show Word option as default, only Wordpad.
Wordpad has now converted all my past Word files to Wordpad destoying the formatting.
Wordpad is not listed in AVG programmes enable/disable
Please help,
Hello Celia. Thank you for replying us back. All the word documents might be saved as the wordpad file due to changes in the selection of the default program. I kindly request you to follow the instructions on the link http://bit.ly/1S4l2em to change the default program of your word document. Thank you.
My Microsoft windows 7 Word has been highjacked by Wordpad.
Now saves all Word documents to Wordpad changing the format in the process.
Urgently need it removed. Also interferes with Google.
Can AVG remove Wordpad and my way ? Can anyone help?
Please help,
