Y2mate solutions?
Hello Eddy,
We'd be glad to help you with this.
You can uninstall 'y2mate' from the list of installed applications available on the control panel. To uninstall go to Control Panel.
- On the Start menu enter Control Panel in the search box and select Control Panel from the results.
- Select Programs > Programs and Features, and then select 'Y2mate'
- Select  'Uninstall'.
- Restart your PC.
hi,
new here but does anyone have an idea how to remove that "y2mate"
windows10  avg internet security
thanks for any help,
eddy
Hello Eddy,
- Restart your PC.
