Zen does not work
Hello Thomas,
We regret for the inconvenience caused. We would request you to run AVG remover tool to completely remove AVG and then re install it.
3. After the restart,  manually delete the AVG Remover folder in the C drive of My computer.
Hi folks, I am a paid user of AVG Ultimate 761. The Internet Protection window and the PC Performance window both have a green arrow in the upper left hand corner that says "Go to Zen" Clicking on this does nothing at all. I ahve 7 PC's installed with AVG ULTIMATE and on all these machines the green arrow works. HELP
P.S. I can't cut and paste all the product info, but according to that screen ZEN is insatlled. I have already done an un-install and install.
  1. Once uninstalled download the installation file using the link : http://www.avg.com/download to reinstall your AVG program.
Hello Thomas,
