Hello Victor
I would suggest you unstall Tune Up from here | AVG (https://support.avg.com/SupportArticleView?l=en_US&urlname=How-to-uninstall-AVG-PC-TuneUp) after you have run this then re-install it. This should resolve your issues.
Hello Victor
My AVG PC Tune-up dashboard says that maintenance has not run for 14 days but when I click on "scan now", it doesn't do anything. Previously it would do the scan and list how many problems there were in each category. When I clicked on "fix problems" it would always get stuck on the second last category and would'nt finish. As a result my PC tune-up icon constantly has a warning triangle on it.
How can I get the 1-click maintenance to run and the how do I get it to fix all the problems and not get stuck?
