1-click maintenance
Hello Eddie,
Thank you for contacting us. Yes, the separate 1-click maintenance icon was removed in the latest version of AVG PC Tuneup. In case you want to create 1-Click Maintenance icon as it was in previous version of AVG PC Tuneup, please follow these steps:
Create copy of the AVG PC Tuneup icon.
Rename the icon to 1-Click Maintenance.
Right click the new icon and select Properties.
Add the following parameter to Target value: /tu.maintenance
The new value will be similar to this one:
"C:\Program Files (x86)\AVG\Framework\Common\avguix.exe" /tu /tu.maintenance
Confirm the change by OK button.
When this change will be made, this icon will start the Maintenance option from AVG PC Tuneup.
Hello Eddie,
Hi.
I have some problems with "1-click" button.
If I want to activate it I have to go through "tune-up" and so on…
I would like to have some kind of short cut!
I think I had one before…
Thanks.
Thank you for the following the instructions Eddie.
To create the AVG PC tuneup icon on the desktop, please click on search on the desktop screen and type as AVG PC tuneup.
It will show you the PC tuneup program name, right click on it and select as send to desktop.
After doing this you can see the AVG PC tuneup icon on the desktop screen.
I tried what u said but it didnt work…
How do I create a copy of tune-up icon?
I hope u can help me…
Thanks.
