Hello Bruno,
Sorry, but we don't speak Dutch. Please visit https://support.avg.com/ for more help or respond back in English.
Hallo,
Ik heb een betalende versie van AVG
Aanloggen met een eID kaart lukt niet.
Ik moet in de "options" kunnen en volgende instelling kunnen uitvinken.
bij "Bescherming van surfen"
"gecodeerde (TLS en SSL) netwerkverkeer scannen" wegvinken
In het scherm van AVG vind ik nergens een knop "options"
Iemand een oplossing
Bruno,
I'd request you to disable each AVG component individually to narrow down which is causing the issue.
1. Open AVG Internet Security.
2. Click on Settings -> Components.
3. Toggle the On/Off slider against each component to disable them.
Hello,
I,ve tryed it but it doesn't work.
Then I also tryed the other combinations, but no luck.
It must be something with the SSL scanning.
regards
Hello Bruno,
Bruno, thank you for explaining in English. Please open AVG Internet Security, click on Menu->Settings->Components->Firewall->Customize->Once this is done, click on "Network Profile(Left side of the interface) and change the profile to "Private" if selected in "Public".
After changing this setting check if you are able to access this eID card with AVG this option enabled.
If you face any difficulties, please let us know and we will assist you further.
Hello,
I can't use my eID card to login to the goverment applications.
AVG is blokking the identification prcedure
I must try to put some options off.
I should open
Options
then find
Protection of surfing ?
then
"coded (TLS and SSL)networktraffic scanning" - switch off
How do I manage this problem
