Hello Jan,
We regret for the inconvenience caused. Please check whether you could find your email id on the right top corner of the program, If not please follow the instructions on the article http://avgclick.me/ActivateZen to activate the AVG Performance program. Please feel free to contact us for further assistance.
Hello,
I bought performance pro but what I try it won't activate. I downloaded it with chrome, firefox and explorer but nothing. On my account it says that it is active but I get all the time the message that I need to update and buy pro. i relogged several times too I restarted my rauter so I dont know it anymore.
Any idea what I can do?
Thanks in advanced,
Jan
Hello Jan,
We are sorry to know that the issue persists. Did you earlier use/install AVG PC Tune Up before installing your new program? If so, please remove 'AVG PC Tune Up' using "AVG Remover tool"(http://aa-download.avg.com/filedir/util/AVG_Remover.exe ).Choose 'AVG PC Tune Up' from the list of programs when detected by remover tool. Please restart to complete the uninstalling process. After restarting , 'search' for a folder "AVG Remover"(usually in 'C' drive) and please delete it manually. And then I request you to install your program 'AVG Performance'(http://avgclick.me/1FmXxG7
). Please follow the above instructions and let us know the status. Thank you.
Hello Jan,
Well I did it all and I got a trial again for 29 days.
Jan
