Alarm Clock Xtreme not showing on lock screen
Did anyone find a solution for this? I am facing it as well with Android 11 on my new Pixel 4a. It worked fine on my Samsung Galaxy S7 with Android 8.
Roger, did you ever get this figured out? I'm having an identical issue. Thanks!
Long press your app shortcut. Go into settings (i). Choose "Display over other apps" under Advanced and toggle on.
I had the same problem just now with my new Google Pixel 6.  Clearing storage and cache, force stop and restart didn't help, but I figured it out.  You have to go to Settings for the Alarm Clock Extreme app and set "Display over other apps" to Allowed. Then the snooze and dismiss buttons will pop up even when locked.
Hi everyone, hoping this is an easy fix. My phone's OS was updated the other day to Android 10. Prior to the update Alarm Clock Xtreme worked like a charm. Alarm would go off and all I needed to do was reach over, grab the phone and hit the dismiss button. After the OS update the alarm sounds as before, but now I need to unlock the phone, launch the app and then dismiss the alarm. Just wondering if there is a way to get back to original way it worked. 3 steps instead of 1 is a tad annoying.
I have tried clearing the cache and data, reverting it back factoring install, have even resorted to uninstalling it and reinstalling but nothing changes. This is the Pro version by the way.
Hi Colin,
We have a separate team for the Mobile products.
Please follow the below steps to contact our Mobile team:
Please click on this link: https://support.avg.com/support_contact_form?l=&retUrl=support_sales .
Select the option as "YES" and the operating system as "ANDROID"
Fill in the details and click on the option "answer via email"
Once your request is submitted you will be getting the prompt answer via email from our mobile team
Keep us posted.
Hi Roger,
We're glad to help pointing you in the right direction. We do have a specialized team who deals with mobile queries.
In this regard, we'd suggest you to raise a request to them via this link to sort this in a timely manner.
Note : You may need to choose 'yes' for the 1st question that is in the above link to request answer via email.
Hi Roger,
I just left a comment here, but it appears to have disappeared. I just found that the Google Clock offers the snooze and dismiss buttons on the lock screen like Alarm Clock Xtreme used to do before I upgraded to Android 11 on the Pixel 4a.
Hello Bill,
For further assistance in this regard, we recommend that you contact our designated mobile team directly.
You can use this link to contact our mobile team via email.
Thank you for understanding in advance!
Hello Tim,
It's good to know that you have managed to resolve it. If you need any further help with AVG, feel free to contact us. Thank you.
