AMD 3200+ CPU + Windoes XP Pro can NOT load AVG anymore
avg antivirus free 2015 self updated to 2016 and crashed. 2016 will NOT install, and any version of 2015
trying to install gives a message "THIS IS AN OUTDATED VERSION" wE WILL INSTALL THE NEWEST FOR YOU.The install download's the new version 2016 and crashes. I have read other reports of this problem and it turn out my CPU can NOT support 2016. What I need is a Stand Alone Offline Install Package for AVG ANTIVIRUS FREE 2015. Can someone at AVG Please so me a link to this package as I have DL'ed 8 different 2015's and all try to upgrade and then fail/crash.
Thank you for your time on this matter … ERJ
Hello Eldon,
We are sorry to inform that we do not have an option to download older version of AVG programs. Even installing using the older link will still install the latest version of AVG. In this case, we suggest you to upgrade your computer to the latest version, so that you will be able to use AVG as usual without any issue.
Thank you
Hello Eldon,
Thank you
