Another with problems with Avgremover
Similar to https://support.avg.com/answers?s=avgremover#!/feedtype=SINGLE_QUESTION_DETAIL&dc=Windows&criteria=ALLQUESTIONS&id=906b0000000D529AAC I cannot get AVG to uninstall.
I had 2015 Free version and saw that the new 2016 version was available, and downloaded that and also AVG Zen. TBH, but without wishing to go into detail, I did not like it and decided to uninstall, noticing that 2015, 2016 and Zen were still present on my system.
Unaware of Avgremover I used Revo Uninstaller Pro for the job, but even then found the uninstall needed manual attention to the Windows registry. Last evening all seemed clear, but this morning AVG was back.
Now aware of the remover utility, I installed the 64 bit version and ran it, but Windows told me that the program had stopped working. What need I do to successfully remove AVG in toto?
Log is available if wanted
Hello Gordon,
Sorry to know that you are not able to uninstall AVG from your computer. I request you to try run AVG remover tool through the following link http://www.avg.com/ww-en/redir?url=http%3A%2F%2Fdownload.avg.com%2Ffiledir%2Futil%2FAVG_Remover.exe&urlSec=UhT%2BBzZUdTGTfMN%2BMUDefLYjJIc5sr9PT4gwqqdOZLdqTfL1KgHh6k4Nsq3ZpPAN%2FWp9nmon7o%2BnrfxaAPzsIjwhTdo1rAQ9hxdvRtYAIhi5T1bfpxwfvmz7mNFa78WW
. Once the AVG Remover Tool has done with its process. Please go to the drive where you installed this tool and look for a folder named as "AVG Remover" and I request you to delete it manually.
Please your issue persists, please get back to us.
Hello Gordon,
