Hello Josefia. Driver Update program keeps checking for all your drivers and update it regularly. These are done by AVG Driver Updater program too. For your AVG PC TuneUp 1-click maintenance issue please try updating the program once and then try the 1-click maintenance. If the issue persists please do let us know. Thank you.
Hello there,
I clicked AVG 1-Click Maintenance. The process was completed, but then a notice appeared saying "AVG 1-Click Maintenance has stopped working - a problem caused the program to stop working correctly. Window will close the program and notify you if a solution is available". Could you please tell me what happened?
I have received offer to buy AVG Driver Updater. Sometime ago I have subscribed Driver Updater with another company due to non availability of such service from AVG. Could you please tell me what is the difference with your service?
I look forward to your reply and thank you
Josefia
Josefia, AVG Driver Updater… For your info have a look @ this webpage (http://www.avg.com/ww-en/avg-driver-updater).
