AVG Anti-track blocking many useful web adresses
It worked for a while,but now it works partially, blocks twitter short adresses - like https://t.co/xxxxxxxx.
This site can’t be reached
The connection was reset.
I want to use fully working product, is it too much to say? It's not free software,so I paid money. Disabling [Enable detection] turns off all detection and there is nothing to see in track hystory. I'm starting to loose my patience to you guys,unfortunately.
We're glad to help you with the info, Lauris.
Upon checking the provided case number, we see that our colleague has remotely connected to your computer & have suggested to disable tracking protection as an alternate workaround.
Also, our colleague has suggested to connect with our remote team, if you experience the same issue.
Lauris, we are sorry for the delay in response.
From your previous posts, we could see that you wish find websites which attempts to track you.
For a more extensive view of your tracking history, select Reports from the left-side panel and click the Tracking History tab.
Hello Lauris,
We appreciate your patience.
We would like to clarify about the "Enable Tracking Protection" option available in AVG Anti-Track product.
If you have this option enabled, then real-time tracking will be done while you browse.
If it is disabled, then the continuous tracking can't be achieved, instead it will be done at regular intervals.
We would like to know whether the issue with sites happens on all of the browsers?
Do you have the browsers up to date?
Did you reinstall AVG Anti-Track prior disabling "enable tracking detection" option?
Hey, I'm agreed with Lauris. The application Must Allow to have a list of the Domains that we don't want to be Tracked. She is not talking about to Queep Tracking in Silence if you change the setting on the Browser. I have the same Impression about to trac or not to trak it not must to be related with the Browser only. Is like the firewalls rules. You can Add the App or the port that you want to release working with no blobking or tracking. It not must be that hard to do. So did you have some proposal to this issue?
What's new about this problem?
It's over a month when I faced these problems, but nothing is changed. what's new?
Hello Lauris,
What should I do? I reported some websites to false positive page, but they are too much.
No,if I turn off tracking detection then everything is fine. But If i do this it turns off tracking protection,right?
Yes, Lauris. Your concern has been already forwarded to the concerned team & our developers are aware of this. It might be taken into consideration in the upcoming versions. Currently, we're uncertain about the exact time around. Thank you for your understanding in advance!
We understand your concern, Lauris. Unfortunately, this is the workaround that is available currently. However, it should list the websites tracking at regular intervals. Thank you for your understanding in advance!
Lauris, we'd like to reiterate that disabling this feature will not stop AVG AntiTrack from tracking your online activity.
It just would not log the tracking in real time. You can still look at the tracking history as suggested by Santhosh in his last message.
Lauris, we have escalated the case to our senior team.
We will get back to you once we get a reply from them.
Your patience is appreciated.
I wanted to know any updates about fixes? anything?
CASE NR: 09443386
Appreciate your efforts so far, Lauris.
Please disable 'Enable tracking detection' option in settings as suggested to resolve this.
If you disable this setting, your browser remains protected, but AVG AntiTrack does not gather data during tracking attempts.
Hello Alex,
We will certainly look into your concern and help you.
We request you to create a separate AVG community post by clicking the link below and post your questions in your own post, so we will check with your AVG account and help you with additional support.
