That's great Akash
Thank You,
Brendan
Dear Sir/Madam,
I followed your helpful email, filled in the details including case number, clicked "Connect to a expert"
and downloaded the remote support …LogMeIn… application.
Im afraid that when I double-click on it, select Open or select Run as Administrator it doesn't
do anything.
Im not sure what to do now.
Regards,
Brendan
Thank you Akash and Alan.
I ran AVG_Clear again and this time I ticked the remove Zen checkbox.
It reinstalled Zen and the icon and I ended up with a timeout at 78% and in the same position to previous.
Hear is a screenshot which shows AVG Antivirus Free in the top LH corner as it appears on your site (assuming it's the latest version) and my installation in the bottom RH corner. Maybe the installation in the RHS corner is indeed the latest AVG Antivirus Free ?
Hello Brendan,
We regret to hear about the inconvenience caused. We have sent an email to your registered email address to run the AVG Sysinfo tool to collect the log files to escalate this case to our senior team who would analyze and fix the issue… Thank you for understanding.
Please, feel free to let us know if you require any further assistance.
Thank you Akash,
I clicked on the First Tile of AVG Zen and installed the AVG Anti Virus Free which is great thanks.
I now have two more queries please.
The first is related to AVG Antivirus Free Web & Email "Not protected"
On AVG Zen Avivirus Free Tile says "not protected". If I view messages within AVG Zen
the message says : "Antivirus Free : your web & email protection is broken. Fix now"
When I click on the "fix now" button it displays "connecting" then "in progress" then the "fix now" button reappears. I don't think anything happened.
Then I open AVG Antivirus Free.
At the top it say "Protection is disabled. It will be automatically enabled after PC restart"
There is a "fix now" button beside it. When I click on it nothing seems to happen"
Under Web & Email it says "Not protected". If I hover over it it says "You're vulnerable to threats. We strongly recommend turning on your Online Shield to block dangerous websites and downloads". To do this I go to Menu, Settings, Components. The fourth item in the list is Online Shield which is set to Red/off. I click on the red circle and the circle moves to the right and becomes green/on. I click OK.
This returns to the AVG Antivirus free menu. Web & Email still show as not protected. When I go back to Menu, Settings, Components the Online Shield is set to Red/off again.
Protection wasn't automatically enabled after PC restart.
How do I set the Online Shield to on permanently please ?
The second query is related to permanently enabling Web Tuneup.
On AVG Zen "Web tune up" was disabled. I clicked on it to go to an Admin-PC Web tune up page. The Browser Plugin, site safety, do not track, browser cleaner and AVG secure search are all "not activated". I click on "open in browser" Google Chrome appears. I click on "Enable extension" in Chrome and now AVG is in control. I close this down and in Admin-PC Web tune up page, browser plugin and AVG secure search are set to protected. Site safety, do not track, browser cleaner remain "not activated" - maybe this is fine. I close and return to AVG Zen and see Web Tuneup is enabled.
When I reopen Chrome it asks if the AVG control is the startup page I was expecting so I can either "restore settings" or "keep changes". I keep the changes and then close it. On the Admin-PC Web tune up page the Browser Plugin, site safety, do not track, browser cleaner and AVG secure search are all "not activated" again. Do you think Chrome can remember the AVG settings please so Web Tuneup will stay enabled ?
Thank you
Thanks again Sarath.
I again downloaded those files you mentioned.
The process took seven hours this time without much progress.
I ran the clear tool. The avguimx.exe "Skype" error I referred to in my last post occurred on many occasions. I ran the clear tool in safe mode, perhaps out of hope/desparation. A reply to one of my previous posts suggested not to run it in safe mode I think. Anyhow this removed AVG Antivirus Free, Avg Security and AVG Zen.
AVG Removal removed PC tuneup. It didn't remove AVG Web Tuneup so I removed using control panel.
I also removed microsoft visual c++ 2105 redistributable (x86) - 14.0.24215 and visual studio 2012 x86 redistributable from control panel.
I read in another reply in this forum about the need to delete the AVG_Removal directory on the C: drive which I did. I searched for further AVG files on the C: drive and hopefully removed them all.
I started the installation in hope.
At the 78% installation point where I've been spending a lot of time recently a network error occurred (see attached file) perhaps coincidentally. Some hours later the error
0xA001004 : wait operation timed out. I used the save log option.
When I click on "Open AVG" in the bottom left hand corner of the screen a message appears "unknown error has prevented web tuneup from installing. Please give it another try and if the issue persists, contact our support team with the error code : 0xa001f90d". When I clicked "ok" AVG Zen froze and I killed it using task manager.
I restarted the PC and restarted AVG Zen. Zen message said "web & email protection broken" as per a previous post. I used Zen to install Web tuneup.
Both AVG Zen and Antivirus are in the same state regretfully as two posts ago regarding
1) Web and Email Online Shield (cannot set it on permanently)
and
2) Web Tuneup (having enabled it it disables after leaving Chrome)
which I mentioned two posts ago.
A little frustrating.
Thank You
Hi Brendan,
Thank you for sending us the diagnostic information from your computer. We have escalated the case to our Senior Team and they will get back to you soon.
Thank you!
Hi Brendan,
We regret the inconvenience and to assist with the issue better we will suggest you to get connected in chat session using the below link.
https://support.avg.com/support_tech_chat
In this link you have fill you first & last name and your email address.
If you need any further assistance, please feel free to contact us. We are always here to help you with your issue.
Dear Sir/Madam,
Just to confirm that I have just run AVG Sysinfo following a remote session with Joel yesterday and have sent the latest output to you.
Regards,
Brendan
I was wondering if there is any update on this problem with installation of AVG Antivirus free please.
It has been ongoing since April 19th with many many hours of uninstalling, removing, clearing, repairing and installing without success.
I did send you the latest log-file.
I currently have no virus protection.
Thank You,
Brendan
Thank You Gunaseelan,
I sent case 04585647 to you
Im not sure if the screenshot attached to it so I nclude it here.
Regards,
Brendan
Dear Sir/Madam,
Hopefully you can help me please.
I'm tidying up my PC and have removed a previous version of AVG which was really good. Never have had any problems until now.
I'm trying to install AVG Antivirus Free 2017 - I have no other security installed.
Prior to commencing the latest installation, having looked at some helpful suggestions on this forum and following some iterations, I again uninstalled all AVG Programs from Control Panel - Programs and Features. I then removed AVG folders from C:\Program Files, C:\ProgramData and C:\Users\Admin\AppData\Local. I then ran AVG_Remover and when it completed I removed the C:\AVG_Remover folder.
I'm using AVG_Protection_Free_1606.exe to install AVG Antivirus Free 2017 which hopefully is the correct version for my laptop with Windows Vista.
At each install at the 78% installation point, which remains for a very long time, I get a popup box entitled "Network Error" with the message : "Another computer on this network has the same IP address as this computer. Contact your network administrator for help resolving this issue. More details are available in the Windows System event log". Maybe this is an unrelated PC issue ?
By now an AVG icon has been created. The target is "C:\Program Files\AVG\Framework\Common\avguix.exe" /zen.open_ui
After another long wait we finally get "Installation failed. 0xA001004: Wait operation timed out"
Google Chrome starts automatically to enable web tuneup which seems to work.
In Control panel - Programs and Features there are AVG, AVG Protection and AVG Web TuneUp programs.
When I run the AVG Icon the description "AVG ZEN" Is displayed in the toolbar and the interface does not resemble the AVG Antivirus Free 2017 interface. It looks like this hasn't successful installed.
Apologies for all the information.
Would you know how to proceed please ?
Thank you,
Brendan
Hello Brendan,
We regret for the inconvenience. Download and run AVG Clear tool: https://share.avg.com/steam/PSP/AVG2017/AVG_Clear.exe. This tool will help with removing antivirus component of AVG 2017 and its traces.
Open tool
User Account control - click "Yes"
Windows safe mode - click "No" (we cannot recommend use the tool in safe mode, because there is a problem with compability)
Choose installed version (AVG Free, AVG Internet Security)
Click "Uninstall"
Click "Restart computer"
Once you restart your computer, please follow the below steps to change the DNS settings.
Navigate to your system control panel, e.g. through the start menu.
-Select "View network status and tasks" or "Network and sharing center" (depend on view)
-Click on "Change adapter settings" on the left. Now a window that lists all your network adapters will appear.
-Select your main network adapter (either LAN or WLAN, depends on what customer is using),
-Right-click it and select "Properties".
Brendan, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hi Brendan,
We apologize for the inconvenience caused, please attach us the screenshot http://avgclick.me/getscreenshot of the AVG User Interface to assist you further.
Thank you!
Thank you Akash,
Thank you
Thank You,
Brendan
Hi Brendan,
We checked the details and no worries we will explain you in detail.
As per your description It seems that your AVG Free antivirus interface is not fully protected. In this case we will suggest you to repair the AVG free Antivirus.
To repair the AVG free Antivirus please follow the below process:
Start-> control panel ->programs(uninstall a program)->select AVG protection -> click on change and repair it.
The AVG Web TuneUP is just the browser extension and it can also be used as search engine as like google and yahoo. This wont make any harm to your PC and you can use your browser securely.
Hello Brendan,
Thank you for providing us the information, we have already escalated the issue. Please be patient and our Senior Team will get back to you as soon as they find a fix for your issue.
Thank you!
Hi Brendan,
We apologize for the inconvenience caused, in that case please connect to our Chat Team https://support.avg.com/support_contact_form?l=&retUrl=support_sales and provide the Case Number to them and they will assist you with the issue.
Thank you!
