Hello Carsten,
We will help you with it. Please try to uninstall and reinstall AVG Antivirus to check if that helps.
Uninstall AVG using AVG Clear and AVG Remover tool as suggested here: http://support.avg.com/SupportArticleView?urlname=How-to-troubleshoot-issues-after-upgrade-to-the-latest-AVG-antivirus-product
Reinstall your products from our official site: https://www.avg.com/en-us/installation-files .
Monitor the situation and let us know its status.
Hello Carsten,
After antivirus update, my PC is freezing and I cannot even restart. I can see under CPU that AVG Service (antivirus) is using between 60 - 97%. I have to turn it off and then on to restart and then its ok for maybe 2-3 hours. Then I get af Microsoft Blue Screen
saying 'power_management, when reaching 100% it does not restart. Then I have to turn off and on again and then work on for a while.
