AVG blocks Thunderbird emails incoming/outgoing
Hello Joe,
Thanks for trying the repair option. To assist further, I would suggest you to disable " Firewall "component first (AVG ▸ Menu ▸ Settings ▸ Components ▸ Firewall)  and check if you are able to Send/receive emails. Also, please disable "Online shield" as well as "Email protection" component.
Let me know which component is blocking Thunderbird to receive/send emails.
I look forward for your response.
Thank you Balasubramanian (Customer Support) for your email. I tried to repair as you suggested, but do not work. Any other suggestion?
Hello Joe,
Joe, In future to keep everything together please try to keep the whole conversation in one question/thread to speed up any resolution. Other posting (https://support.avg.com/answers?id=906b0000000Dq8BAAS).
Hello Joe,
I appreciate your efforts. To assist you further, we need to collect diagnostic information about this issue. I have sent you an email, please follow the instructions to collect the log files. Our concern team will analyze the files and provide you with further information.
